storm7576;701993 said:you should get a reliable mechanic to check the car first before buying. I have mine checked, and found out the valve cover gasket leak. Get the key fob checked at AB to find out the actual mileage, lucky it telly with service record. If your car got sunroof, asked the dealership to tie the drain pipe with cable tie. Experienced mine came off once, and flooded the front passenger seat. The water came out from sun visor
shahnaz;702361 said:I am also looking at the X5 E70. I was wondering whether we can change the IDrive on a 2008 UK Spec X5 e70 to CIC that the current F10 and X5 2010 models use ?
On another note, there is also a listing on mudah for a BMX X5 XDrive4.0d
http://www.mudah.my/BMW+X5+4+0+x+dive+3+0cc+m+sport+diesel+RM40xk-12993948.htm
Question here is that does this model can actually take the the diesel from malaysia ? The engine is a BMW M57TU2D30-TOP model. The 3.0d is using the M57TU2D30 model.
Pretty interested in this model but am more worried about whether this car is suitable for Malaysia diesel or not
shahnaz;702441 said:Thanks storm7576. What about the XDrive 4.0d ? Any thoughts on that.
shahnaz;703393 said:Naza is offering a X5 2007 E70 at 19000km UK Spec for RM320,000 ? From a price point of view is this reasonable ? the car seems to be in solid shape at least from the outside. Need to get a mechanic to check it out.
Safri, when you say local dealers for the 2011 model, who are you referring too ? I believe the 2011 models are still running at RM5xx,xxx
