the rpm is not stable
firdaus79
hello therei need to know, my e36 engine got problem with the rpm. it is not stable. sometimes, when i drove the car and stop at the traffic light, at first the rpm will decrease below 500 and then the engine will off/dies.i just change my airflow sensor one month ago but the rpm is still same. i sent my car to one of the mechanic at batu cave and he also cant fix the problem. so now what should i do.for information i am a new user with this car and just bought it about 2 months ago. please help me sifuu..
u should send send yr ride to bavarian benz budget workshop at jln chan sow lin..
mine had similar problem, and now its perfect. probably need a few days to solve the problem though...
bro..refer to threads...lots of discussion on this problem.
mine...(idling problem )its due to throttle body and injectors problem. Its so dirty resulting delay in engine combustion.
And did replaced the leaked/broke cleaner hose too....throttle body and injectors they takeout for servicing.
firdaus79;483639 said:
hello there
please introduce yourself in the newbie section.
how to help when we dont even know you.. :rolleyes:
pss..stt.. check for leak in the vacuum hose. :listen:
hi we are wt the same mechanic.. mr.check.. :top:
