suspension
datsunnismo
dear all.need advice from you guys...my e30 platform always hit the road humps evertime i drive through it with passanger. and the car looks lift infront if with passanger in rear seat.so, someone suggested to remove the rear spring mounting ( the base plate like cone), place 1inch plate at the bottam and welding back the spring mounting. is it advisable? any other idea.
Bro datsunnismo...ur body m20 right?? Correct me if i'm wrong,why u use m40 engine in m20 body?
My e30 oso same problem,it happened only when with passenger at the back,mine using eibach spring + boge absobers
Got any idea/advice anyone????
hi bro. it was converted to m40 when i bought.
just to update my experience.
today i've placed a extra spring pad on top of the rear springs. now the problem solved.
Bro, what type of spring pad u used for rear springs??
Someone suggest me to put spring rubber at the centre of the spring...
I got the used stock upper rubber pad from my friend. cut the cone and make it flat and and placed between the mounting and the existing pad. thats all.
