Mel279 Club Guest Joined Oct 16, 2013 Messages 177 Points 28 May 16, 2014 #1 hi Im having issue with my steering wheel vibrate when idle but when the car running its gone. Anyone know what causing it?
Herbert Well-Known Member Joined Sep 8, 2009 Messages 4,443 Points 83 May 16, 2014 #2 Most likely engine mountings are worn out causing the vibration.
Mel279 Club Guest Joined Oct 16, 2013 Messages 177 Points 28 May 16, 2014 #3 I have just replaced I think the left side only, might be the right side worn out
S slyder Official Member Joined Jul 29, 2011 Messages 903 Points 43 May 16, 2014 #4 Hi Bro, With mountings its always better to replace one set. As its normally done as one set. if one gives way normally it means the other will give way soon. cheers
S slyder Official Member Joined Jul 29, 2011 Messages 903 Points 43 May 16, 2014 #5 But vibration can be cause by misfiring as well
Mel279 Club Guest Joined Oct 16, 2013 Messages 177 Points 28 May 26, 2014 #6 I've decided to replace the other engine mount and see how it goes
