Sloppy Shifter in E34, advice needed, what about SSK?
morpheus5039
Dear all sifus, I have a sloppy shifter(gear shift have free play), I know have to change bushings, etc. But I just dunno how many parts to get.Below is the picture i got from www.realoem.com
Please advice which part i need to change.Also, what if I change to z3 1.9 short shifter? Just buy the z3 1.9 shift lever(part no. 25 11 1 434 148)? The rest juz change the required bushing parts?Thank you!
Hi there, u are right... get the z3 1.9 not too long not too short... 2511 7 527 252 alternatively you can try the 328 or ///M shifter 2511 7 527 247
The rest is item no. 2,7,8,12 x 2, 13, 14 (i think come in a set from 18-20 inclusive), 15 x 2, 16 and 17. Just did it on my M40 for Getrag. Yours looked a bit different tho.
You can compare to mine:
http://bmwfans.info/parts/catalog/E...july/browse/gearshift/gearbox_shifting_parts/
I bought item 2,7,8,10x4,12. Clip 11 can be reuse so i skip. I also got the Z3 1.9. Good, not too long, not too short.
And while your GB is down anyways, might want to consider doing this:
http://www.bmw-sg.com/forums/classics-e21-e28-e30-e34-etc-etc/37037-transmission-problem-my-e36.html
(also did mine recently, now the gear knob spring back to neutral very firmly. previously every morning I had to do a hard knock to get into the 5th gear drain before it become usable.)
All the best!
yup...u can get the z3 one or u can get from UUC. the shifter as well as the dssr. both are nice
