guys, i duno if any of you have his problem, where the rear bumper is drooping slightly at the front /wheelarch edge?i performed surgery on mine at the weekend, removed the rear wheel, then removed the splash guard (easy, two plastic nuts, and some plastic rivets) that revealed the culprit !! theres a black plastic bracket the holds the bumper cover to the car, it is adjustable, but mine is broken, its an easy fix when i can locate the parts, and will tidy up the appearence of the rear bumper.... for now i made a small metal clip to hold the bumper in the correct positionwhen i replaced the wheel i also smeared copper grease on the mating surface of rim to hub... this stops chemical reaction from bonding the two togetherjust thought id share the easy fix info.
