RPM up & down during idle
JAY_KL
Hi guys,today morning having problem with RPM goin up to 1 and coming down to 0.5 when car is left idle, it keeps on doing that until the car gets warm up, anyone has this problem before? how to fix... pls help thanks
It could be your ICV (idle control valve) clogged up. It needs cleaning to free the air flow. Btw what's your engine code?
JAY_KL;754075 said:
Hi guys,
It would be helpful if you state your car model, year and engine spec. Not all BMW are built the same.
if that's not the case then it could be the idle control valve that needs to be cleaned ..as mentioned by huskar above ...OR a loose hose connection where your ICV sits ..
OR try checking your plugs as same thing happen to me but upon cleaning the ICV problem still persist and once i removed the plugs i saw oil condensation on the ceramic tip due to a worn plug gasket ...so end up changing the engine top cover gasket ...
Thank u guys:top: , i shall get it inspected in 1 week time & update here whats the rootcause
