astroboy;300134 said:My Auto Bavaria E90 did alignment job at Sg Besi.. FOC!! Still under warranty ma..
keeekeee;300166 said:just called Sapura. they said under 1000km then alignment is FOC. is tat true astroboy? mine over 2000km already.
astroboy;300160 said:Few days after I drive the car, I realised the steering is pulling hard to the left when on highway and wobbly steering when let go the hand..
I went back to AB and complain car doesn't feel right. How? They dare to charge me ah!!
GHS;300117 said:Shudn't be becos of RFT. I have done alignment/balancing a couple of times with a reliable tyre shop and I'm on RFTs. About RM50+ or so should cover both items.
Illusion;303780 said:E90 325I and above only got the active steering system......
And almost all new 523I and above got the active steering......
Set the alignment for sure no need any software to do it so, BUT the software need to tell the system the alignment job is carry out. If not the steering angle will lari like HELL..... That y they charge that crazy amount...... Have to pay them
Juan Powerblow;303791 said:Yeah. I can confirm that! I finally got my alignment done at AB Segambut for a whopping RM380. They pointed out the need to set steering angle vis-a-vis Active Steering software and also, there's a screw that needs to be removed to set your camber (negative camber) which other service centres didn't take out when they did alignment. It's expensive but worth it for me cos my steering never felt this good as after the job by AB.
