Rear light warning
drweko
Hi everyone, Im a new comer to this blog, thou I've been using this bm for the last 16 years, little is known about the mechanics of it haha. Just to share with you guys, hopefully you can help me with these problems of mine: 1. If I start the car after than 3 days lying idle, initially the engine kind of misfiring as if it's running on 5 or 4 cylinders, but later it will be ok after a few kilometers.2. I've changed the rear light bulb after the warning came out on the dashboard, but then the warning wont go off.Anyone care please, just trying to diy.
Bro you may try to check on your
Q1.)
Q2.) Try to ask your mechanic to plug in the diagnostic tools to erase the error code.
Hopes this info will help and your udm may recover as normal.
Thanks Alex for info. certainly I will go to my mechanic 2mrw. Will let you know asap, once I got those fixed.
