Rear Camber Toe Kit - where to get???
BGklenz
Where to get this things here? I need it for my E30... ;) Pls help.....I get this adv from internet....
REAR CAMBER TOE KITThis is a complete rear camber/toe kit for your vehicle. 82-91 3 Series E30Tired of wearing tires quickly? Then an alignment kit is what you need! Correcting camber will allow for reduced wheel squat/costly inner edge tire wear and improved traction. This is essential when lowering, load carrying, or when expensive low profile tires are fitted. This kit utilizes a unique, patented single wrench adjustment and no special tools are required as a bushing extraction tool is included!
try K-mac......not cheap.
alternative is use uni-directional tyres and swap them around more often......corner faster also helps! SERIOUS.
Got mine ,with helps our now missing in action Loneranger. Unlike Jules...I still brakes while entering corners. He DEOSN'T brake at all!!!
You know why?....cos I drive SLOW mah! Ppl brake at Sepang T1 at just after 100m mark..... me well past 50m cos only travelling at 80kph mah!!! :D :D :D
Sorry, off topic but just some humour ok.....
KMAC KMAC KAC......not easy to Malaysia boleh fabricate this one!
KMAC selling nearly 1k wooo:eek: .... i think better start to learn corner faster! :D
Want to fabricate locally is not really difficult. Just need a bit of volume to start the ball rolling... So who wants a set? I'll try to get the machine shop guy to see what he can come up for me...
Alternatively, there's a stock offset mount from BMW which you can buy.. Try checking the ETK.. I recalled someone mentioned he bought a set of those to correct the really -ve rear camber.. But it's not variable.. Once set, can't adjust like the KMACs
nahh... i really belive in spirits of malaysia bole! count me in... but all depends on $$$ la.... hehe..
