Rear Subframe Camber & Toe Kit vs KMAC Rear Camber Kit
usually a very bad - camber is due to either a bad subframe or worn arm bushes...
using this correction kit helps for those who uses the track often.
get the bavarian ones, the k-mac squeaks a lot....
hi pussy,
i've changed all rear trailing arm bushing with oem ones last year yet the problem still persist.
As u can see below on the left is the problematic side. When ride with more than 2 person the tire will rub.
Right side seems to be fine.
Could you suggest me a good workshop that can solve my problem.
I would prefer not to get the e30tech rear camber kit as it involve welding and re boring which will affect the subframe mechanical structure.
Thank you in advance.
View attachment 25074View attachment 25075
your rim offset too far out...must be e11...i have used e13, still okay or your rear is 9j ?
can't be rear absorber sag or the spring end broke ? what year model is yours ?
when my rear chamber was out......i changed all my bushings on the trailing arm. It did not help so i did the next best thing, changed the arms. That solved the issue. So do remember that the rear arm can deform over time too....
my rear is 9j... doesn't seem like and absorber sag or the spring end broke... it's a 1989 m40
do you know where can i get the arms? when to optimum and they say it's hard to find these days..
kedai potong......ya, not easy to find so you need to search slowly or use your network like in here!
you were right jules.. i've changed my trailing arms and everything went to normal again :)...
