I've problem with the radiator. I sent for checking but the is no leaking.The water level would always lessen. I've to top up the water, like one in every 3 days.Kindly shed me some light on the matter
Yeap! i'm totally agreed with pussy. I had gone thru the similar experienced previously
that I need to fill in a lots of water within a week. I've found out my water pump failure
with leaking water on it. Then, had changed the new water pump plus labour cost as
rm350. After changed done, nowadays no more leaking... :top:
another possible leak is at the heater core. if the core leak u wont notice it when u do the pressure test as the leak cant be seen...have u done the bypass? if not its time to do so b4 the core really koyak big time ...
