Racing Oils
Traxport
Was talking to a BMW specialist and he mentioned that instead of using the normal oil done by AB (I think is BP) ; try to use racing oils for improved performance. The entire oil change + filter etc...cost RM1,xxx.xx. Anyone has any experience in this and what is the best engine oil for our BMW ? Please do comment on this. Thanks !
LOL. Racing oil ? cost RM1k ?
Dont' fall into their tricks. Most sythentic oil will work just fine.
Best engine oil ? no such thing. Only regular oil change is the best.
Cheers
Cheers
:top: agreed. i think if you change your engine oil with any fully-syn with the correct viscosity every 8-10k KM, your engine will be very clean and last very long. i am not sure if you guys still remember the mobil 1 ads. in TV. it shows that the car using mobil 1 with 300,000KM on the clock (that is about 4 or 8 times distance around the world). they dismantle the engine after 300,000km and found virtually no wear & tear*. if you guys notice at the end of the ads, there is a small fine print below and if u read if quick enough before it change to colgate or nescafe, it says *based on 5000km oil change interval with mobil 1
if i remember correctly, its not advisable to use racing oils for our car cos in racing they change the engine after every race :)
just use recommended oil and change regularly and you'll be fine. sounds like ur mechanic is trying to make a fast buck. and while ur at it, change ur mechanic too.
