problem gapo ni....
Raiha
Hi guys...perhaps you brilliant sifu's here can help me out. My E46 is having this problem. not so smooth in starting the engine in the morning although it starts anyway. the engine also suddenly died after the i start the car. this usually happens after i've driven the car & turn off the engine. i went to see my mechanic and he changed the spark plugs. he said if that doesnt help, then it could be the trottle body (dont know what this is....). well, the car still like that. the engine starts for few seconds, then it died. very frustrating lah!!
Bro ,
Get the throttle body & ICV cleaned / serviced .
Usually this the main culprit for erratic idling .
The flow is air intake , air filter , ICV , throttle body .
Good luck !
Bro,
Same problem with my UDM before, after service my t.body & ICV and problem solve.:top:
Raiha;342032 said:
thanks so much! really appreciate it.
bro..which part of kota bharu are u staying..i often go there as i am half kelantanese,i'm afraid its hard to find bmw specialist in the east coast..if u know then please let me know the location ya..thanks
p/s:good luck with ur problem..be sure to let us know how it turned out ok.
there is a shop in KB called Indah Workshop. num is 097487831. Heard most benzies and bimmers go there.
Hellraiser;355766 said:
sounds like air flow meter problem. had the same problem myself
bro.. E46 don't have AFM.. AFM have been replaced by MAF (Mass Air Flow Meter) which eliminate the moving vane that tends to stick up.
