plate tank leaking
zekm59
hello bro.. i like to know.. some water leaking (slow n continuesly) bottom of the expention tank.. than.. my mechanic said.. the problem at the plate tank... and recomment to replace PLATE TANK.. when i saw the plate tank diagram.. CAN ONLY O-RING NEED TO REPLACE... than HOW MUCH COST FOR PLATE TANK... thanks for u all
I have changed mine when I did a full coolant system overhaul. It cost rm180 (BMW) from BA or RM140 from Munich auto (OEM)
Hi bro....
What model is your ride...
If it is leaking better change it but not sure bout the price...
Aku ada stereng bas ko adaaa....
bro...call bav auto 03-56350000 and give them the part number..from the diagram you will be able to cross ref to the part number....
Bro Zekm59, I bought the item at about RM169.00 from BA subang. Not sure how much in KT. should be around that range.
IMHO, change the expansion tank as well if you haven't done so. Plastics tend fail at about the same time.
em...weird...seems like the left side (Expansion tank side) of E46 Radiator is a weak point....usually leaking happen on this side but seldom heard the other end got problem... more pressure on that side?
Ok all in only rm230.... labour rm50... plate tank rm130 (Munich auto).... join triangle rm50...
Reasonable price, where you did your repair ?
