DIY Rear Brake Pad for 320D (N47) 2010 Manufact.
Tools to remove the wheels
Wheels off and retaining ring removed
Locate the upper guide bolt (requires 7mm allen to remove)
Locate the lower guide bolt (also requires 7mm allen to remove)
Tools to remove the guide bolts
this is how the allen key is slotted to remove the guide bolts
locate your reservoir for your brake fluid and make sure it does not overflow during the whole work
here is how the guide bolts after removal
use a G-Clamp to press the brake solenoids
after removal of the outer pads, remove the inner pad with the sensor (only the right rear wheel have the brake sensor)
remove some bolts to gain access to the brake sensor connector
this is how the sensor slots in the inner pad.. WAIT, place the inner pad into the caliper before slotting the sensor!
Now reverse the whole work to complete the job
removed pads vs new original pads
note: i have no clue where the DIY thread is in our forum.. so, i am posting it here temporarily :top:
Cost DIY Rear Brake Pads
here..
