Paka Kuantan TT (East Coast Bimmers)
harisbimmer;729214 said:
regards...for our info my wife n ec773 already discharge from kmc today...just finish nasi beriani together....tq
Good to hear that, shukur!
Alhamdulillah. Wishing both for speedy recovery.
BTW, yang sorang Dato tu bukan have to "check-in" balik kar? :wink::wink:
muhaiminrahim;729161 said:
can someone put up the report of poor workmanship from halim workshop, beserah?:4: we need to share this finding between ecb's laa..
:top: ...... its not the end bro, probably the beginning of a new era .... the passion flows where the senior can take a cue on this .... :top:
:listen: oledi in meng ......:frown:
hospital dah kuorkan waran tangkap...:date:
Salam semua kengkawang ECB
Tahniah tuk Mr Prez & newly elected CM juga
Bagi yg terlekat dikatil hospital harap2 segera sihat dan kembali ceria
Lefthanded - the next time I'm in the east coast, you and me we have to talk about the JOY of being an OM.
faizata report (part#1)
29/01/12 - Kereta alami minor overheat problem water hose to transmission gearbox tercabut.
- enjin susah start bila panas and water loss - no leaking (enjin-minyak pelincir) no abnormal sound .
04/02/12 – 1st Paka Kuantan TT
05~09/02 - TT with ECB member muhaimin,choq & cat mintak enjin dan workshop yg bagus utk BMW.
10/02/12 - kereta ke BM Auto Station(Halim) masa anggaran
17/02/12 - kereta siap Top overhoul cost RM3170. masa ambil no leaking observed (part yg lama x tunjuk pada onwer)
19/02/12 - found minor engine oil leaking (sedar mase start nak gie keja kesan parking ( already told halim – nanti bila next engine oil change kite tgk kata halim)
23/03/12 - back to BM auto (halim) to change engine oil and engine oil leak checking – change GASKET-FLANGE only. No thorough inspection perform just try and error method.
24/03/12 - minyak pelincir masih bocor kesan kat lantai masa parking. Dah bagi tau halim.
25/03/12 - went to KL ada training 25~27./03/12.
faizata report ( part#2)
26/03/12 - hantar kereta ke Jln klanglama PJ (AMS Autogarage) pit stop E46 bimmerz club. Founds- bila buka Cyl.head cover visually observed lots of oil sludge still remain inside head compartment and camshaft.- coil plug penuh minyak ,spark plug pipe(condom)pecah- paling worst fixing clamp utk oil pipe (atas camshaft lubrication system) patah dan tertinggal didalam engine – >metal and very hard to broken.- conclusion like no top overhoul even perform before.- markin utk timing chain pada luar engine like x der special tool claim BMW specialist dah ler lari 2-3 degree - semasa di AMS ada buat compression test e46 N42 engine every cylinder should get 14.++ bar pressure but 1st and 2nd cylinder 11.++ bar and 3rd valve seal dah leak – valve seal datang sekali dengan top set gasket kalau buat top overhoul – x sepatut nye leak.
27/03/12 – call halim bagi tau kereta problem dan halim minta repair yg leak sahaja (clips yg patah x jumpe masih dlm engine )buka camshaft untuk install balik condom ,tunggu part dan re-assemble cost me RM 590.00
My car @Stuttgart, Sunway just now. Notice the cleanliness and tidiness of the workplace. IMHO this is what our workshops in the East Coast should aim for; work ethics. The rest will surely follow..the workmanship will increase and by time they will be known for their quality services. And we wont have to deal with such a lousy case like what Bro Faizata is experiencing right now.
p/s: Sorry for my poor English conduct but Ive heard theres some complaints regarding 'thrashy language'. I dont know what the heck does 'thrashy language' defines to but just to be safe..
Bro...what model is this?...335i?
clakak sungguh halimm..sama sdiri pun nok kecing jugok..dok pakka gawa mekanik lagu ning..
translate : i know halim, he is an honest mechanic,...faizata, u better talk to him nicely..:thefinger:
muhaiminrahim;729559 said:
i hope someone can translate faizata's report:4: dunkdie, how come u still in kl? have gurl ther kaa?
Good translation Abe Jak............Bro Min, tot Abe Jak is the right person to translate Faizata's report kekekeke
