noob with idling problem
nazira96
:hello: I'm new here and need help with idling problem with my 520i A 1995 that occur whenever the car is static and aircond on. The rpm goes up and down but not when the aircond off. :dontknow:Hope the sifus here can help
Has to be one of these:
1.Idle Control Valve
2.Throttle Position Sensor not positioned properly
3.Carbon build-up inside the throttle body(Just clean up using WD40)
I would do the process of elimination starting from No. 3 and work your way up.
Thanx for the info everybody, my problem has been solved by bro Remy n sifu Sham thanx to Mr. Planta who introduce me to them. I am now have been relocated to Melaka and still looking for good workshop around. Any suggestion?
check with the melaka boys... chilie30 and redhotivan...they know where to go..
cheers..
HI Nazira,
What was the actual problem with the idling?
Could learn a thing or two from you :)
