I went to work this morning, the air conditioning system suddenly stopped working, it was fine last night..increased the air flow (full blast) and NOTHING. No air flowing, shut the system down, turned it back on and nothing...compressor and fan running fineso went to mechanic to check the problem and they said blower problem or panel problem which is cost around rm1k above and maybe more..so expensiveand i did some research (read from another forum) same problem - the only thing need to be replace is Final Stage resistor - just want confirmation from you guys - any of you guys experience with this problem?or any advisehow much the resistor cost? thanks
