"Ngot" sound when turn on uneven road
shama
Dear sifu, my E70 have this "ngot" sound when turn right and especially over an even surface or on a inclined road. Mechanic said the lower arm needed to be replaced. So i replaced the arm as per what the mechanic said but the "ngot" still there.... what could be the issue here?
This is difficult. I cannot imagine this "ngot" sound.
Aku ada Tapatalk. Kau ada??
This "ngot" sound seemingly coming from the steering as I turn rightward and especially over uneven road surface...
If it goes ngot ngot ngot as you are turning, it could be your wheel bearing - ask your mechanic to check the wheel bearing
Is the ngot sound comes out once, or repeatedly ngot ngot ngot ngot?
My experience with bearing is that it will come out on straight roads.
Anyway, i still cannot visualise how this ngot sounds.
I am also have the sound with my E70 especially with the front right, wonder if it is the absorbers.
Mech check and cant find anything wrong, have been leaving with it for the past 1+ months.
Yeah if there is sound on turning the tie rod may be the cause. I had this problem before while turning on one side.
YES!!! especially front right. and is obvious when the road is uneven..
did u change the tie rod and sound go away??
The sound is not repeatedly type... just once or a couple when turn to the right over uneven road
Yes i did change it and the sound went away. The sound i had is repeatable and everytime i turn on one side (cant remember left or right and its a continuous sound like clack clack clack)
