Hi all,My car is ready for next Sepang F1 session and to limit the understeer, I'm thinking of have negative chamber in the front like...-2 front, -1 rearSincen BMW suspension is dead one, what kits should I look to enable that modification ?
for the front, the only option is adjustable camber plates... I think for the rear, it's sufficient... Just need more front negative camber to reduce understeer...
Are you carrying way too much speed thru the corners? (overpowering the tires)
Camber plates will help...assuming you get it adjusted just perfect.
You can also play around with tire pressures to help reduce understeer
(next time you go out, take note of your cold and hot tire pressures and adjust accordingly)
You can get the car aligned...set up a little toe out to get better turn in. My car is set up with 1/16 toe out and it helps. The straight line driving sucks though.
You can also change your driving style...couple of driving techniques/throttle steer etc to cope with understeer.
BTW....Sepang track, u guys run clockwise or counterclockwise?
Interestingly that was how Munji setup my GTV for Sepang. The standard car understeers quite a fair bit and with this setting, negative front and 0 degree in the rear, the car is a dream on the track. There is just so much grip and it goes like a dream. Mind you that this setup works perfectly on the GTv as it has a live rear axle hence giving it a degree of passive rear steer which works well.
