need ur advice...
alantiong;728056 said:
I think i know what is it the train horn sound. It is the plate behind the disc rubbing on ur disc. It is a thin piece plate so when it heats up.. It warps and kena the disc. Get ur mech to push it further from the disc. Always happen after changed pads or disc. If i am right... Do let me know.
but the sound was there when raining n every morning ....can u display the image what u meant that plate behind the disc rubbing on my disc....??thanks..
kedudukan plate tu betul2 belakng disc...sis u can see easyly wen u look at the disc.....than amik screw driver panjang push the plate a bit behind so tk begesel dgn disc lg...if that the culpurit la...chearss
boyburhan;728128 said:
hey sis\
i agree with alantiong. The plate behind the disc mite b the culprit... touching the discs or one of the disc.. but then when u r x braking, sound is x there huh?
Is the ABS lite turned on?
no..the ABS lite turn off... yap..just when i brake , the sound was there...only every morning n when raining...
Fireuz;728141 said:
Interesting sound.. memula, bunyik "brummm brummmm", then "nyiiii nyiiii....", now "utttt uuuuttttttt".. macam keretapi tanah merah pun ada laa... This is complicated problem from sound.. so u can make a free concert in your neighbourhood :24:... Just kidding..
Actually I had this problem back 2years ago, and alantiong is right, it's because of metal plate behind the disc (look like disc cover if im not mistaken).. If the sound still persist, try to make proper lyrics for it, and enjoy the song.. hahaa -joking again.. jgn maraa kak.. :aetsch:
:( ok i try first...but if the sound there...come n joint my concert...just FREE...but bring some popcorn n coke..n i will make a proper lyrics just 4 u... :rock: lets sing together.... brummm brummm nyiiinyiiiii truuuuttt truuuutttt.....
hah lega...paham2...mmg plate tu akan terkena bila kita tekan brek ke??i hope the sound gone after this...doa 4 me... :)
Horn keretapi mmg pernah denga zaman2 naik kretapi mail dulu...kuat tu sis!!??:eek:
Bring ur kreta to another mech la sis.. how much hv u spent with ur current mech already and still not solved?
BaddBoyz3;728209 said:
ooo like tht ka.. the solution could be one of the comments below the video, remove pads and grease up evrything except for pads & disc
Good luck!
yap...already snap that comment below the video... anyway thanks...if everything ok...i blanje u all 'teh tarik' :) ..doa 4 me ok.. :wink:
seems to be like a jammed caliper ...where the plunger is not reversing back hence causing a stagnant pressure exerted towards the brake pad and continuos rubbing to the disc ....time to service the brake calipers ...
others problems that could possible be
1) wheel bearing
2) ball join bushing koyak
3) tires which are not even
etc etc
do keep us update ya
1) wheel bearing
etc etc
OMG...so many problem..anyway thanks ...i already call my mech..they dont check the calipers..they ask me to send back my car 4 service...aduiii...
becarefull sis anta balik for rectfy the prob tkpa ..if tambah prob means tambah wang keluar la..hahahh...btw ur hubby tk tlg tengokn ker??
first time i pergi bengkel..dia charge..but 2nd times, just free... my hubby...tgk je la... :)
calipers jamming are dangerous ahhh ...may cause extensive heat exerted to the disc which may lead to a cracked disc or even worse a sudden brake jamming during high speed ...just get it sorted out soon ...don't play play ahh
errr...is it?ok boss... thankssss... :)
Alex5522;728348 said:
err..you don't think so the brake was the most important part of our rides ?
sori..yap sure the brake was the most important part of our rides..but i dont know about the calipers...what it 4..what is it..but now i know what it is...thankss 4 all ur info... :)
