Need Help, E30 difficult to start.
Originally posted by ammar@Jun 9 2005, 11:39 PM
Hi ctan,
It seems the key switch barrel/column/set/harness, have some contact problems just same like mine. For 3 days i have to start my car through contacting the starter. :cry:
What i did, open the stering column, buy 1 new push button switch. Get 2 new wire, try contacting both new wires by attaching of each 1 of the new wire to one of the 7 wires at the key switch barrrel (can't remember which wire colour, try and error), but ensure key put in start position. A little bit of spark won't hurt you :eek:k:
Wires it to push button switch.
And now you start push button switch just like some of the scooter/kapcai/motorcub etc, sorry have no picture.
Or.. you can "bang" the stering column for a kick start. Sometimes it work.
u shud use a relay when u wire it liddat
Hi Ammar & skinhead,
Thanks for advice and I will try it......
Hi Logan,
Do you try before?
Just curious, will a weak or failing timing sensor (aka pulse sensor) also contribute to hard starting?.
A mechanic told me that this could also cause hard starting (need a few cranks to start car) if the sensor is weak. Anyone can confirm this?
yup, as moots experienced it b4
Originally posted by cntan@May 13 2005, 03:17 PM
Hi Franklin,
My plug wire was been change full set cost me about Rm1k++, the end still same condition at all and this problem make me feel to sell it the car because other people though "lauzy" BMW car.
Hi D.V.NG,
Pls. tell me in more detail like photo locate the location cause i am the outsider, i really want to try even there is left only one percentage chance for my car, i also get mad to my car when want to start the engine and the last choice is too be change the total engine to SR20 nissan engine once my money have extra.
Thanks.
cntan, can PM me where you go to get your car rewired...thanks
Finally after 8 months of plug n plays to replace whatever .......... :cry:
My warm start problem found .......n it lies inside my fuel tank....
it's my fuel pump.... :blink:
This pump has been replaced just before i took over from the previous owner.
Problem : The pump is together with the damper could'n hold the fuel inline when it is warm. So need to crank few times for it to achieve the pressure needed. :yahoo:
Cost of repair: 1) Cop Shop Fuel pump RM 120.00 (after 2 weeks hunting)
2) Labour : D.I.Y. with 3 cans of chill tiger.
3) Time : 30min.
Hope this would be helpfull.
cntan - Any progress in your UDM?
Check your fuel pump as well.
FYI:
M40 91 fuel pump - new 1 cost RM7++.oo.
3) Time : 30min.
FYI:
Hmmmmm......thanks logan......ada spare ka itu pump..ha ha ha :wink:
No Sparelah ...........n5zm :dunno:
Try chop-shop in subang area.....
Maybe can find.....loh. :rolleyes:
