Need Advise
KelvinTeoh
Banned
Anybody have Experience in E46.Because of the ''TAK'' sound,i spend for the Engine Mounting,Front Angle Arm Mounting,But still sound still have,the sound ''TAK'' came when i revearve parking[fully turn the steering wheel]then it will have the sound,Any Idea?
Hey Kelvin,
U should listen carefully. First what u need to do is turn your steering wheels to the MAX left and right. Is it both side have this sounds. If only 1 side you should send to mechanics to disassemble your tire portion on that particular side. Somewhere should gone wrong with your shaft. If both side also sounds "TAK" u need to ask them to check the joining portion between the power steering bar and the tire shaft. Hope this will help u to find the root cause of the problem.
yes, i agree with acidburn, from my experience, if u turn your steering fully to left or right doing 360 degree turn (sometimes u dun even need to turn fully the 'tak' sound also come out), i think most probably is either the drive shaft or absorber. since u already change your front lower arm, u should look into the above mention 2 item.
