Racun Mode = ON
I would say take the 320i if its a 6 cylinder... if you enjoy rounder finish to your car then this is external consideration... If just outlook you can choose latest version...
For me Actually i owned a 318i before (well kinda company car not 100% mine) when i was in KL for about 2 years this is based on 2 year 318i and MY own 320i which i own almost a year now... so im still quite new to BMW as well just IMHO:
318i or 318is are 4 cylinder engines and are well underpowered by any UDM standards, approx 140BHP and 180 NM of torque...
This is a very reliable car and DIY super friendly (i learned a lot from this car and fell in Love with UDM when i met her
although reliable, they aren't very exciting to drive... This i found out when i try to overtake as well as when moving from stationary position (missionary is never a problem
). it is just personal preference in the end since the comparison is little to none...
get the 318i if you want a reliable family/personal car which save more fuel in the long run as well as maintainance cost. BTW the difference of about 70KG if im not mistaken will make the difference with oldeer 320i with 4 cyl engine... if compare 2 4 potter... i'll go for 318i any time of the day hands down no need to think again...
The 320i or 320ci is in another dimension Beast where the 6 Cylinder is smooth like butter (if you maintained it well) ... with approx 150BHP with 220 NM of Torque......
(The extra torque makes all the difference really)
If you like speed and power as well as crazy stuff like Need for speed under longkang and gila2 drift tokio kedai buku style its not the 320i are built off for... PERIOD...
But mind you with some "adjusting of the limiter" if you get the older 6 potter say the E36 with Tracktion off = crazy mode... make Big Apple or Dunkin Donut oso possible
Here is what i just known and the most exciting bit
The newer 320i has the same engine as the 323 and the 325!!!!!!!! YOU KNOW WHAT THAT MEANS, RIGHT?? YES, if you get the ECU, Exhaust + manifold, and Oxygen sensors from a 325 and put it on your 320, you have just boosted the BHP to 175 and the torque to around the 260 mark. Now dont say i didnt Racun you enough...
In the end my advice is get the 328i
