Alex5522 Club Guest Joined May 28, 2010 Messages 2,324 Points 38 Jun 26, 2010 #1 Hi All !Need advice on changing Lower Control Arm. Will it okay for changing ONLY 1 side the Lower Arm since it was the wear & tear parts.Thank you.
pswchan Club Guest Joined Jul 10, 2008 Messages 74 Points 0 Jun 26, 2010 #2 Alex5522;536635 said: Hi All ! Need advice on changing Lower Control Arm. Will it okay for changing ONLY 1 side the Lower Arm since it was the wear & tear parts. Thank you. Click to expand... Can you buy only 1 side? Better do both to be more balanced and change the bush as well. I did it in my E46 and it changed the handling and there was no more clonking noise.:top:
