My UDM
After all the paint dry fix the rear caliper kit. Must be done in tender but hard to avoid tearing the rubber & must grip properly for full satistaction.
Then installed the rear disc
Then installed the caliper & completed rear disc brake system.
After all front & rear brake system installed need to bleed & of course E60 being electronic freak, the brake fluid warning pop out.
Using Bosch brake fluid Dot 4 made in germany. Apa tulis pun tak paham. hahaha
Dun use dot dot dot made in balakong....
My E60
The brake servo & fluid reservoir. Take the opportunity to clean up as well.
Fill up brake fluid slowly to avoid messing up the area and at right level.
bro, never try DOT 5.1 ?
NKTOB;629882 said:
Going diving? which pantai are you heading to?
I'm travelling there end mth too, with 8 students + 2 leisure divers...to Kg Genting.
Idk, which pantai i'll be at... but for sure i'll be staying at berjaya tioman island resort... will be there together with 4 other college mates. Planning on going snorkelling, but don't know which pantai is the best... hope you can give some info on this.. pm me bro ;)
Enkil,
Yup bro, wait to see how the mech did it.
Sach,
5.1??? never heard before. Minyak urut ka?
More repairs for my E60. Front passenger power window switch is not working.
Repair the door panel clips & holder.
Repair front headlamp wiring
My E60
My airconditioning has been acting intermittently. So no choice but have to go for major repairs.
After diagnostic the front sensor shows faulty error. So have to change brand new ori sensor.
Then changed new aircond compressor.
Denso compressor using valve technology not usual magnetic clutch
Next changed the condensor & filter dryer as well
Take out the condensor & to clean the internal compartment
Old filter dryer.
Old & new condensor with the filter dryer inside
Take the opportunity to clean aircond filter compartment internal area.
Clean the aircond carbon filter.
After dismantle the aircond filter housing to pieces. Clean & dry before installed.
ayo amma appa...wah, that's quite a major repair n damages..hope it wont burn yr deep pockets...cant wait to see the end results..keep us updated bro..
he got 10 pockets laaa bro Bad...:listen:
keep cumming bro IM..:top:
Thumbs UP!!
choq@PAKA
Actually all the repairs & mod done has burnt big hole in my pocket redy but no choice as to prevent breakdown & enjoy the driving.
Luckily the bank has offered me low interest flexi payment. Thanks Citibank!
badrul880;630303 said:
He has very deep pockets lah. This is sap sap soi only.
will have to learn how to deepen my pockets..i'm now dreaming of cuntchill......zzzzzzzzzzzzzzzzzz
