My UDM
Take the opportunity to clean under air filter box as well.
My E60
Next is to change auto gear oil & auto filter
Dismantle auto filter oil pan & drain out old oil.
Old auto filter oil pan
New ZF auto filter oil pan
Since all leaking problem solve & undercarriage preventive maintenance & checking done, clean all the undercarriage cover.
My E60
Since all cover dismantle, take opportunity to clean the undercarriage where possible.
Before
After
My E60
Next is to change front engine wear & tear parts and all cooling system
Radiator bleeding nut
My E60
Some of parts changed
Behr Thermostat with housing
All the bearing & tensioner
My E60
Old thermostat & water pump. Good to change if you dont know the history. U never know when its goin to give away
Installed bearing, tensioner & thermostat
New water pump install. Need the take out electric fan.
Then installed all the belting (continental) and hoses
Using mineral water & BMW coolant for cooling system
Bleeding air in cooling system via the expansion tank till the electric fan kicks in. No bleeding nut for this engine.
After all this engine preventive maintenance giving her some mandi buih.
Soap it
Rinse it
Dry it
Bro congrats on your newly acquired monster....
what's the total damage so far just for preventive maintenance you've inccured....just for a rough estimate if one wants to buy an E60 530i?
cheers.
ur next up on the e60 arr bro? hehehehe..e39 track car la!
Bro IM, congrats on ur cuntchill. Im sure ur chilling alotta cunts around in ur ride..hehehe ;)
