guru
- Oct 25, 2005
- 773
hey fellas,I contemplated this for a long time and wasn't sure to post or not. As you can imagine- this would be quite a negative post.My story begins with the purchase of a set of H&R lowering springs from Motorsport Division at Sunway. I've been there many times buying all kinds of stuff before and sometimes came out unsatisfied with their workmanship. However I gave them the benefit of the doubt and continued to shop there. I got this set of springs early this year(08) and they(Marco Chen) installed it at a workshop behind their shop(a malay guy with superbikes). Marco was there the entire time, supervising.
the bill - 'including installation'Months passed and the steering feel detiriorated..i couldn't quite put my finger on it but got it checked out at my regular mech which worked out that the lower bush needed replacement. 400 bucks later, it seemed to be ok.fast forward couple months later(oct 08)- the steering didn't feel right again, there was an unusal feel when driving slow over uneven surfaces, if felt like the lower bush gave way again. Also the tyre wear was eating on the inside a little too much than normal. I took it back to my mech and he checked out the steering rack that seemed to have lost it's rigidity on the shaft. He suggested a repair kit and see how it goes. A complete replacement was the last option and very costly. 650 bucks later it was still the same!!Needless to say I was concerned that this may turn out to be very costly indeed.As they tinkered with the rack, one of the mechs noticed how the the pin that attaches to the lower arm rod was not aligned straight as it should. And after comparing with another car realized that the struts were mounted on opposite sides!! Can you beleive that? What crap I went through and money wasted on needless repairs when the root of the cause was some struts mounted the wrong way around! the left strut was on the right and vise versa. After switching them around the problem was fixed and all the nuts ligned up properly. But now the tyres had to be replaced because the uneven wear was causing the car to pull one side.I really don't expect Marco or Motorsport Division to take any responsibility for their mistake and I never took it up with them. I don't expect to be compensated either. I feel if I did take it up with them, it would only make me more upset and I might lose my cool over some money and pride.THE COSTS - 400(lower arm and bushes) i dunno for sure if the struts caused the failure or maybe it was time to replace them anyway.650- repair kit for the steering rack, I know for sure this was money wasted.3000- 4 new goodyear tyres, I HATE uneven wear. If your car is setup right, this won't happen.4 days- wasted my TIME! Not to mention it could have been a safety hazzard! What it the steering failed at high speed?Moral of the story- THINK TWICE AND DOCUMENT EVERYTHING PPL DO TO YOUR CAR. KEEP AN EYE OUT FOR ANYTHING. EVEN THE SO CALLED EXPERTS MAKE MISTAKES.* I will upload pics later.. I suddenly very free and decided to report this but i'm using someone else's pc.
-what it should look like
- mine not looking right
-view from left wheel arch
http://s147.photobucket.com/albums/r318/marclee/shocks/th_IMG_0200.jpg- fixed
