My "kereta kebal"
Perfomance wise..not changed much from previous setup. Actually if you want gain noticeable increase in HP, you have to go with performance header ( mine still virgin )
but....with new setup, low to midrange pickup is much better than JFA. Sound wise, more civilised and a bit quiet :D. JFA is bassy and rough
Complete view for the new exhaust setup
Rear wheel alignment. Quite hard ..all dengkil tire shops gave up. So I sent her to Ekuine Park...managed to reduce the toe from -2.5 to -1.25
Went to sunway today and.......New nose :D
Went to naidu today
Atf oil change using bmw atf fluid
Aircon filter replaced
Leaking sprinkler tank repaired
Accident happeneed in very rural area in some kampung in batu pahat.......and here's the new adventure begins..
And there's a hobbit in hobbit hole...
Front ori m sport bumper torn into pieces after clashed with the mighty stone.......
The new bumper arrived swiftly and with new fog lamps.....The msport T bar is being reused
The blacksmith from elven wood putting the front bumper back into the place
The black gate of mordor
Front look
rear look
he he...........so far aku puas hati cara abe tuh buat kerja...kemasss yg amat :D
Yeah satisfied til habis bumper lining ko tertinggal kat workshop kehkehkeh.
Good to know u like it bro. Since problem solved, please help reg yasef for coming genting sempah ride ok
kereta bro nasir macam mana ? semua sudah installed ?
AKu ada tertinggal barang lagi ker ?
