Meter cluster connector
kacyp
Hi all, need some help on the obove matters. i DIY change of meter cluster. Basically i can see 3 connectors behind the cluster with the color blue, yellow and white, when i opened up my ori cluster i found that there only the blue and white connector is connected. Is this normal? i try to find the wire with yellow connector can't find.FYI my previous ckuster several gauge is not working, when plug in new one all working accecpt speedometer. Maybe some can help on this.Thanks :D
why nobody answer aaaa? :getyourfactsright: :getyourfactsright:
white and blue is the right connectors.. connect the blue connector to the blue socket.. the white to the white socket..
the yellow is for other system.. not used in M'sia..
aiyoyo macha..it is for auto box la.. he he he..
no-lah taiko, it's for the OBC system.. i'm using the yellow sockets for my car..
thank you.
thank you.
then why you say straight? :p
