Wiring Connector
Strider
My central locking intermittently not working. The problem are at the wiring connector at the driver door pillar. One of the pin already in bad shape. Am thinking of changing/rebuild the connector. Anybody know where can I get the wiring connector (e30). I don't mind if it is used. Already tried to get it from Autobavaria PJ but n.a. Or else can someone advise me on the size of the connector pin and place where i can get it.Thanks a lot.
which pin is in bad shape.. The plug or the socket ... or the locking actuator or the wire connector..
The plug damaged a bit in the process of unplug it, but still can be use (preferable to change to a new/used one in order to prevent the water from getting in)The real problem is the wire connector (similar with item no. 1 - female) I don't know actually which one but it is a female pin. One of the wire connector are damaged a bit (it is a red wire) After one weeks of opening and closing the drivers door, the central locking refuse to work. What i do, I use a small screwdriver and push the particular pin and the central locking works again. This will be repeated again after one or two weeks.Any help are very much appreciated.
Originally posted by Strider@Dec 23 2004, 08:45 AM The plug damaged a bit in the process of unplug it, but still can be use (preferable to change to a new/used one in order to prevent the water from getting in)The real problem is the wire connector (similar with item no. 1 - female) I don't know actually which one but it is a female pin. One of the wire connector are damaged a bit (it is a red wire) After one weeks of opening and closing the drivers door, the central locking refuse to work. What i do, I use a small screwdriver and push the particular pin and the central locking works again. This will be repeated again after one or two weeks.Any help are very much appreciated.
I might have this female socket some where in my store. It gold plated but it is slightly longer.(manufacturer by ELCO) Don't know whether it will fit into existing connector housing. Do you want to try it? I will pass it to you one these day at the TT.
