Manual Getrag 260/5.....
Iqlima
Hi manual driver 5er,Just for possibility in the future.Nothing wrong with my auto.trans but use to drive manual heavy car before switch to E32.Is all M30 engine car or Getrag 260/... manual will fit E32 730i ?Anybody know who right guy to talk with ? 535i /nsborne !Thank you :lol:
Mine comes with Getrag 260/6 - the fin model.
naza2 customized his 535 with Getrag 260/2 - dog leg
U can fit (with modifications) Getrag 260/5 to ur engine but I think it is limited to certain torque only. E28 535 uses this gearbox
If u can find the Getrag 260/8 (I think .. meant for M5 3.6) ... it will fit nicely to ur M30.
I am talking abt M30 post '89 model.
Frankly, thse gearbox configuration is very very confusing.
Value info,do you have link so I can read more on this 'confusing" Getrag 260/....? Before I start dig on E28 would try to look into E23 Getrag first.
What you say on this ?
these box can definitely fit your engine:
getrag 260
getrag 260/5
getrag 260/6
535's gearbox is quite nice. overdrive ratio but bulletproof. given if you can find it.
getrag 260
getrag 260/5
getrag 260/6
Forgot to mention on list about your name for person should ask for, my apology
How do I differ on this getrag model, by their physical look or need to see on gearbox serial no plate itself when visit chop shop ? You have a link for me to browse ....
Many thanks
Hi Ig,
You will need the DRIVE shalf from a E32 manual becuase your auto driveshalf is too long. Do not potong and joint!. Balancing a changed driveshalf is a very tricky thing and only professionals with right equipment should ever attempt!.
No point getting the tranny fitted and alamak, cannot drive the rear wheels!.
Its a serious issue you need to solve.
There are a few shops here in KL that has this 'dynamic balancing'.
I hv tested one .. Not perfect but to me .. acceptable. Cost me RM 700.
It's hard to get a manual long-shaft for E32 7 series here in KL.
yes, I check out in www realoem.com , the long shaft between auto and manual where the different roughly 100 mm.
I'm still digging info about this Getrag 260/5 which on shark version and 260/6 which the right one for e32.
Never know about "dynamic balancing" ? Guess balance something while it move (dynamic) !!
Collect info first .......
Thanks
Thanks
Keep us posted ..
I am interested as well ... Can trade info
