fabianyee;414168 said:A cheaper Bilstein Sport alternative for the rear shock would be the Merc Benz W124/W202 rear shocks.. Slightly stiffer to the Bilstein Sport.. And best if it's already run in aka used... Then again, that's just for the rear.. U'll need a matching front shocks to go with the rear Merc shocks... I'm using Titan's serviceable front shocks. Or u can opt for the Bilstein sport front shocks.
rayncc;414386 said:Hi Fabian,
Will the car maintain a balance height at front & rear using the front Bilstein Sport shocks & rear Merc shocks set-up?
Also, is the rear Merc shocks a direct bolt on or require certain fabrication/modifications?
Cheers.
nawtyboy;414358 said:wat do u mean by ' ("i know e30 cannot use 17inch"-still in search of an ori 16/15inch) '??? ur statement made me kinda worry though....
i m using 17' on my ride, seems fine to me le...??? care to eleborate? any consequences that we are looking at?
evilnickwong;414410 said:Fabs, how much would a setup similar to yours (Titan front shocks + used Merc rear shocks) cost? I sometimes think that my black Bilsteins paired with H&R springs is a tad bouncy sometimes.
535i: Speaking of rear mounts, anyone here with contacts for reinforced+redesigned rear mounts? e.g. the Rogue Engineering ones, those are tasty looking.
535i;414455 said:I'll stick to the ori from BMW + less harsh rear abs.
Lesson learned - coz i need to double-weld the rear mount plate - it cracked due to the hard rear abs.
fabianyee;414460 said:Need to install proper strut bar (that cover the top surface) to reduce the mount plate flexing during bound and rebound....
535i;414467 said:Fab - done that wayy back - infact the mould that we are using now for tht plate, originated from our Kosas gang back in 1996 !
Still - not strong enuf to hold the Gabriel Gas ..
But that strut bar is the best investment to improve ur E30 handling ..
fabianyee;414517 said:This design is based on the Sparco aluminum strut bar flown in from US... U used the super stiff Gabriel Gas absorbers meant for the Pajero, sure koyak loh...
evilnickwong;414527 said:Fabian, no feedback on rough price of the Titan + Merc combo?
rockonla;414451 said:i was told that it does compromise handling and it might shorten the life span of the wheel barring. also e30's are not designed to drive on 17's as 16's are the max option available last time. theres a few more issues about this but i dont remember. so far i use oklah, no problem. i dont drive my e30 hard all the time, just the occasional dash arnd corners for lunch.
