Looking for a used windscreen water tank
GasWombat
It's for a 1994, E36, 325i. The plastic around one of the sensor (the bigger one) has chipped off and can't hold water anymore.Have been checking with 3 workshops that service Bimmers but so far they can't source for it.The replacement tank must still be in good condition. If you have a spare one, pls PM me.P/S: Lately my steering column seems to squeak when i turn to the left. as if there's lack of lube....No sound when turning right. any clues on what might be causing the noise and whether i should have it look into.
Try the chop shops, plenty around Puchong, Klang and near Ingress (Bukit Lanjan).
If you ask the workshops you sure kena chop one!
try chop for the spare part.
As for the squeak sound, it is the bearing just located under the the steering wheel.
Remove the steering wheel and check the bearing just where the shaft of the steering column.
There is a possibilty that the plaster holder for the bearing is lack of grease or have worn down.
You can check this by shaking the steering. If there is some free play, it mean that the plastic
holder is worn out.
that was not very good/suitable for a lady to own a BMW.., that car was popular for young MAN in the WEST.., europe and America.. due to multi-ply X $$$ in these country, it became older people to own it...,
Usually Apek-apek/Datuk-datuk/manager or just rich-rich people; most of youngster did not had change to had it and experianced on it.......
