Looking For 2.8 M52 engine
acschnitzer
Hi to all sifus,Can any sifus here advise me on where i can get a 2.8 M52 engine and what the cost of the engine will be like? Thanks
are you using a 320i vanos??
anyway, are you searching for just the engine ( head and block only) or a frontcut ( complete engine, harness, dme, ect.)???
I say bro.. want more power ar ?
yes, in kl got engines... very expensive.. please check that the current ecu is siemens management..
who said expensive...??? just becos he from Singapore..???
You want ah....you know who to call..... :)
There is one "engine kosong" for sale at one of the chop shops around Puchong. Asking 6k or so.
If you are currently running a 320i, you would need an ECU remap, otherwise you will not harness the full potential of the engine. ASk me how I know? :p :)
how do you know?
let me guess... you've also spent many years doing research on getting that lump into your 520i...
Bro, i am currently running a 2.0 single vanos engine, am actually looking for a M52TU engine that runs on double vanos but guess that will be very difficult to come by so will be looking at a 2.8 single vanos instead, for remapping, i will be using O-bit to do the mapping, currently alot of the 46ers over here are also using O-bit to remap their ecu after SC is added on with a 3.0 M54. Would appreciate if you could pm me some chop shop numbers so i can call and ask around, thanks.
Hi Leforte,
I am just looking for the engine, not looking for a half cut. Will change the torque converter for myy current transmission and prob. change the rear axle for the correct ratios later.
Hi bro, din get to see you during the grand tt coz i was late. Am looking for a 2.8 now but will be using my original ecu as i will be using O-bit to remap. SC is also in the pipeline after the 2.8 is done.
Hi Zogee,
Who can i call to enquire for the engines? it would be much appreciated if you could advise me on this. Thanks
