TheTinkerer;794364 said:It will not. I have tried if with an occupant (adult) inside. I walk away (to run some errands) with the engine running. The engine will not shutdown but a warning message will be display on the screen and the car cannot be driven under that circumstance. I think it's due to the immobilizer.
irfan80;794366 said:That make sense...I thought can drive....did u try to drive? Maybe if the car move...then oni the engine off...
irfan80;794383 said:Woo...it can be cool or it can be worrying oso....
Atmosphere Motorsport;794382 said:the engine wont die off. my wife did once from Setia Alam drove to Midvalley only she found out she leave the key at home.
splee;794581 said:I think something is very wrong here. The car should not be able to drive without the key. This is simple logic. Sounds like the security system only check for the key once only when we first start the engine. Thereafter the system will not check for the key again? This is not safe. Can someone verify or check on this with BMW Malaysia.
Momoco;794764 said:Its true, after the car was start, and someone removed the key from it, it will show a msg say the key is not found, and the car can still be drive somewhere around u wan it be.
Unlike W212, if the key beeen removed, once the car's break paddle been engage, it will auto shut down the engine.
So, don leave ur car started by removing the key and leave it away, could be in danger of losing it.
