Is this absorber OK?
ELnino
View attachment 22464BMW E39 Front -Rm182 Per (Pcs)*Pass 1 million cycle test*Pass 300 hours salt spray*Use silent block (solid handling & noiseless drive)*Meets Japan JIS Standard*Long Lasting performancewhat u guyz think about this absorber?
Price is not bad...............can i a try. If my absorber is out for sure will buy this 1 .............hehehehe
Since it damn cheap can try la but dun forget to share the outcome here.
If i try it for sure will share all the info. I always share the info which is confirmed dont worry.
What absorbers are these? Damn cheap!! I think I may have to replace my rear absorbers. If these are good, I would consider these. Where can I buy from?
you can find it in mudah.. just type e39 under car accessories and parts
Bro,
Why want to risk putting such type of absorber onto your 530i? The so called "Meets Japan JIS Standard" absorber is made in Sungei Besi.
If i am not mistaken a guy name Mr Lee from Bangi are selling this and they have a factory in Bangi on this asb and air mass sensor too.
herbert;711002 said:
Bro,
buy 1Malaysia la....we got 1clinic, 1pasarraya, 1mamak, now we also got 1kilangabsorber. :)
You are right Alex...i also gave him a call sometime last year...the adv sounds convincing though but I still ended up with Sach...
Tires, suspension and braking systems are critical components and one should never take any risk and compromise on safety.
I was email them on 2010 then they follow by calling me but i am same as you bro..end up with Boge on front(x2) at BA he..he..
You forgot something la 1Ghee
Bro,
Really? Was not aware of that. Thanks for the heads up Herbert. Stick to bilstein then.
For someone who doesn't want to take any risk and doesn't want to spend ( a.k.a waste to some ppl, :) ) time like me, I won't think twice not to get a used absorber set for E39 unless you know its history, knowing it takes so so so so much effort to replace the rear ones!!
