Just my humble opinion. A wax or sealant like Turtle Ice will just be able to clean a little bit of the paintwork and then seal it in, protecting it from our harsh environment. If you're looking for something that would bring your paintwork to a glossier and shinier finish then you'll need to go for something that can also do a little bit of 'polishing'. Something like Meguiar's Deep Crystal Paint Polish or ColorX, 3M One Step Cleaner Wax, Optimum Poli Seal, and I'm just mentioning some of those that are available locally.v_ice;407846 said:Hi bros
Been using Turtle Ice (rm98) for 4 months. Not so impressed by it. Also used Ice Clay and Ice shampoo. I tried many microfiber cloths and am a great believer in it. Is there better results by other products? :wink:
CleanWorldPeace;409222 said:Hi Guys,
Are you guys doing the detailing yourselves? I always thought this requires some experts to ensure a professional finish.
My ride is less than a year old so the paint work is still quite new. Guess no preparation needs to be done. Can I just get the Meguiar stuff and the buffer and start buffing away? Sounds like a total novice and I am...
Regards,
seech;409457 said:CWP, u sure you want to get started detailing your own car? Its like drug's..... first you buy some Meg's products, then you buy a Bosch ROB or G220, then its a Makita and thousands of dollars of detailing supplies.... Don't ask me how I know....
IF you want more info can check out:
www.meguiars.com.my/forum2/
www.meguiarsonline.com
Or check out my friend fish's blog:
wetshinedetailing.blogspot.com
Good luck and may the force be with you.
CleanWorldPeace;409711 said:
Hi seech,
Looks like I really need the force and all... I guess to maintain the paint work at its tip top condition is the tough part and each time you touch up, you probably need to do an overall for the car! Is that a fair assumption? What do you suggest? Leave it to the pro? Wouldn't that cost even more in the long run?
CleanWorldPeace;409896 said:Hi guys,
Thanks for the update. I called up a Meguiar outlet called Ardy's in PJ and somebody there told me that a basic(?) detailing will cost RM500 for my Z4(small size job). He thinks it will last for 1 year but if I wash the car regularly with the 'right' products and have it polished/waxed every 3 months with the 'right' products, then it may last longer. Are the cost, before buying the 'right' products, and timeline about fair? Will the 'right' products cost a bundle?
There other thing to note is if later the cost become too prohibitive and you stop the usual maintenance, will the paint work deteriorate to even worst than a normal coat before detailing?
Regards...
CleanWorldPeace;409945 said:So B33mEr, when is your next DIY round? Since you are in Subang, it may be easy to hook up. I am in Saujana.
