bebiloku Club Guest Joined Dec 13, 2007 Messages 14 Points 0 Jan 8, 2008 #1 How To Remove The Idle Valve From Bmw 520i E34 1993 With Out Remuve The Manifold ,and How To Clean The Idle .
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Jan 8, 2008 #3 Extract from Bentley manual. Take note : for E36 6 potter..
bebiloku Club Guest Joined Dec 13, 2007 Messages 14 Points 0 Jan 9, 2008 #4 jarance;278023 said: Extract from Bentley manual. Take note : for E36 6 potter.. Click to expand... THANK YOU ,PLS WHERE TO DOWNLOAD THIS MANUAL ,I HAVENT THIS
bebiloku Club Guest Joined Dec 13, 2007 Messages 14 Points 0 Jan 9, 2008 #5 redbaron;277992 said: Yes you can but it is not easy. Click to expand... YES TRUE ,TO DRUB MY HAND WITH IT
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Jan 9, 2008 #6 bebiloku;278351 said: THANK YOU ,PLS WHERE TO DOWNLOAD THIS MANUAL ,I HAVENT THIS Click to expand... There used to be a link in the forum that will tell you where to download. however, not sure whether the link still worked. BTW the file is about 90 M. I will try to locate it for you later.
GT-E39 New Member Joined May 15, 2005 Messages 499 Points 0 Jan 9, 2008 #7 bebiloku;278353 said: YES TRUE ,TO DRUB MY HAND WITH IT Click to expand... This kind of job better past to machanic !!!there do this also not easy.
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Jan 9, 2008 #8 GT-E34;278779 said: This kind of job better past to machanic !!!there do this also not easy. Click to expand... I think our friend from Albenia is a bit of a DIY person. It can be done if you have the proper tool..
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Jan 9, 2008 #9 OK found the link. Goto post #14 and clink on the link as posted. BTW, it 93M. hope you got broadband to download the pdf file. http://www.bmwclubmalaysia.com/forums/showthread.php?t=9220
bebiloku Club Guest Joined Dec 13, 2007 Messages 14 Points 0 Jan 12, 2008 #10 jarance;278800 said: OK found the link. Goto post #14 and clink on the link as posted. BTW, it 93M. hope you got broadband to download the pdf file. http://www.bmwclubmalaysia.com/forums/showthread.php?t=9220 Click to expand... THANK YOU ANY SOLUTION FOR MY PRO HERE http://www.bmwclubmalaysia.com/forums/showthread.php?t=16618&page=2
