How much the cost involved to convert 328i e46 to 1jz?
fahmi757
hi,i) Is there any e46 owner that convert their car to 1jz vvti engine?ii) May i know the total cost of the project?iii) Any workshop that you can recommend?(KL or Sel area) Hope someone can assist me....TQ:)
thanks for all d replies...i prefer workshop around KL or Selangor area....its easy for me to go for check n inspect on my car progress during the conversion...:)
sifu need to know if the E46 318 chasis different from 6 potter chasis?mountings engine compartment etc?
fahmi757;717476 said:
Prob with my g.box n rear axle also need to be repair.
why dont you convert your auto to manual, and turbo your current engine? :) how many horses do you want, 300, 400, 500? can be arranged. how many gears you want, 5, 6? also can be arranged. hehehe....racun racun
decided to maintained the existing engine and just send the car for gearbox replacement and inspect the rear axle together with the long shaft....hoepfully after this everything will be all right....:)
How much?kena racun ady.to convert the engine to turbo?
no turbo la:burnout:...no budget..huhuhuhu..i will only change d g.box n ask d mechanic to inspect the rear axle together with d long shaft...huhuhu...at 1st 1 wanted to change to 1jz..but after heard advise and opinion from forumer and my friends, still prefer to maintained the original bmw engine.....
if conversion not done properly, it'll be endless trips to the workshop...
Anyway, if rear axle problem, change engine would solve the issue cos u'll still be using back the rea axle..
