H hpteh72 Club Guest Joined Dec 14, 2004 Messages 73 Points 0 Feb 4, 2012 #1 Anyone had encountered with the CD stuck in the HLG OEM Multifunction DVD player? I have and need some help and advise.
bmw7833 Club Guest Joined Oct 14, 2006 Messages 9,160 Points 48 Feb 4, 2012 #2 Take out the player and push a bit on top, the disc will come out. The loader alignment is lari from the disc entrance.
jarance Founding Member Joined Dec 4, 2004 Messages 14,743 Points 63 Location KLlang Feb 4, 2012 #3 The only time it can stuck is when the flexible ribbon cable is blocking the CD slot or maybe the gearing is worn out due to warp CD. See below to gain access to the CD Changer.
seewai S62B50 Joined Feb 29, 2008 Messages 2,119 Points 48 Feb 4, 2012 #4 Ini procedure macam the one I used to removed stuck tape cartridge from tape drives hehehe.
bmw7833 Club Guest Joined Oct 14, 2006 Messages 9,160 Points 48 Feb 4, 2012 #5 If u know what i draw..
Alex5522 Club Guest Joined May 28, 2010 Messages 2,324 Points 38 Feb 5, 2012 #7 Mind to sharing did the problem solve, btw i think HLG not the OEM stuff of BMW. Thnks
H hpteh72 Club Guest Joined Dec 14, 2004 Messages 73 Points 0 Feb 6, 2012 #8 Alex5522;711765 said: Mind to sharing did the problem solve, btw i think HLG not the OEM stuff of BMW. Thnks Click to expand... I took out the player and shake it a bit. Then the CD came out when I press the eject button. Weird.
Alex5522 Club Guest Joined May 28, 2010 Messages 2,324 Points 38 Feb 6, 2012 #9 Thnks for the update bro any way do enjoy your lovely ride and the music too..:rock::rock:
