Help needed...unknown issue
pam312
Hi sifus...need some advice
This morning after starting my car...noticed the airbag light keep blinking
Second is my steering buttons no longer function and the steering button lights is off
Third...during reverse gear, PDC button light blinks as well
Car can be driven...have not gone to mechanic yet
What could be the problem?
when a bimmer lights up like.. its an indicator of a bad battery or bad alternator or something to do with grounding. dun worry about each and every alarm/lights/indicator that goes on fault. when it all comes up at the same time.. its normally just a bad battery.
Bro, check the ignition switch in the steering column. Simptoms of a bad electicity current.
bro haywire.....you are right....
diagnosed and confirmed ignition switch issue. got it replaced.
but i'm still having another issue....PDC light blinks during reverse, suspect rear sensor problem.
will check tomorrow morning
bmw scanner 1.4 will normally show if there is problem with the reverse sensor. well it did in my case.
