sangkuriang
- Dec 13, 2006
- 43
- 6
Hi all and sifus, Humbly reporting that my ride E46 320 (2 litre model, Jap spec 2001) has no power. Its not a problem in the morning, only after it travels certain distance and engine temp stabilised and restarted for next journey (after stopping for breakfast or something) that this happen. When pressing the accelerator, the car is not responding and the RPM revved to 2,000 to 2,500 RPM only. Further movement in AUTO mode only initiated by d car dropping down the gear to move forward and continue cruising, still no pulling/pushing experienced. This is weird as if somehow fuel/air mixture issue or something else. Please advise what should I check (other than the OBC) like ignition coil, spark plug, engine oil, air mass sensor, camshaft sensor, clutch plate. The car was serviced 7,000km ago and regular items changed are oil filter, fuel filter (very dirty), air filter.If any of you sifus/friends out there ever experienced these, please share and enlighten my mood.Thank you in advance.
