Headlight problem
bmw7833
When i pointed to a wall, i got this:
The right side higher than the left side for 1.5", it is about too much for me.Any idea to lift up the left side light?I know my left side headlight adjuster is broken, but is it effected so much the 1.5"? :stupid:
Bro,
from the pic it looks like right is lower than left. Either you buy new one or replace the adjuster kit.
Bro, the new one cost RM2K ler, i dont think i will dump the money lar..
Will the problem really solve if i change the adjuster?
I got this contact sometime back. The headlight adjuster could be replaced. RM 180 per lamp. Try calling this number 03-80623848 (Ken)
u can buy the headlight adjuster at your normal BMW parts supplier at around the price that Jerman mentioned
Aiyah dun use cable tie lar. This is BMW & 5 silies wor. Paiseh wor:love:
bro,
There is what DIY all about :top:. Anyway, it's under the hood, what you "don't see, doesn't hurt", right?
As long it works why not.. You should see the number of cable tie, jumper wires and what not in my engine compartment... :listen:
I dun care lar as long as it can raise the light..Sumore my headlight cover still very good in condition, so it is a waste for me to change whole the headlight..
Jerman;422889 said:
bro,
AGREE!
I think i have solve the problem as my fren put a plate on the bottom socket to give it the force.
Will upgrade later after i try at night. Cheerrss..
Aiseh..problem still there, only raise a bit..Decided to change the adjuster, sad to see the cover soon to be open.:20::mad:
Changing the adjuster is still the best way..
By turning the angle even by 1 deg, the beam will have moved about 10mm at a distance of 20 meter.
