Originally posted by Calvin Tan@Nov 21 2005, 09:15 PM
[Hello DanPromote,
My battery are located at the rear trunk too. I just connected it to the battery terminals. And I have installed a Pivot Volt Stabilizer (PVS) without the ground wires (because I have just cleaned my E30 existing body ground not long ago) And I think the Pivot ground wire is too small. So I decide not to buy the ground wire, if I want I will make it myself.) OK, back to the topic. After I have installed the PVS, nothing improve on the performance. Just brigher lights and higher voltage by 0.3volts and voltage is more stable then before. Like on/off A/con, headlight. Well it worth the money.
Since this is not that costly, I went and bought another one for the front terminal (the terminal that normally use for jumpstart) This time performance did improved (I will say quite noticeable at all rpm range).
Improvement more than performance air filter and exhaust system (exclude header).
well just my 2cents to share with those who are planning to get one and need some feedback from the end user...
