Its been a while since I had any problem with my E46 until just a minute ago, The display of P,R,N,D is missing.No sign of jerking or anything, just a weird "tick tick" sound on the gear handle.Anybody experience anything like that?
Simonso I had the same issue and now my car already in workshop. Better check immediately as mine the symtom was same and at the end the Oil cooler for the Transmition kaput and oil already mixed with water in my water tank...what you can do now...open your expension tank and check the water ...if it's teh ais color you already too late...if not...better go and send to workshop for check...if already become teh ais..the damage in your wallet will be more for flushing....and part replacement..
I also not sure why...as the error that I've got is:
1. 1st gear ratio error
2. 2st gear ratio error
2. 3st gear ratio error
4. Position Sensor A intermittant
Did asked Kenny last week, he said if the oil cooler faulty and water get into the gearbox..need to flush the oil and change the Gearbox switch sensor as the sensor might become faulty ..cannot get in touch with water..the sensor will shortcircuit.
maybe.. but simon car can still drive but no indication only at the instrument cluster. If gear position switch is kaput, the car most probably cannot engage gear.
Anyway the indications is back to normal after i did a car service. Even though it doesn't link to anything but i also changed the panels on my driver side door. As a result, the airbag has to be taken out and the ECU is required for a reset.
While at it, the mechanics did a diagnostics and only found 2 errors with the car.
1. Airbag seat sensor going funky
2. The heater sensor is not functional.
Been driving hard around town for about 3 weeks after the problem, no signs or symptoms about the disappearance of the indication on my dashboard.
Another point, the car has no problem switching to other gears. Seems pretty smooth and i tried playing with the tip tronic, its awesome! heehe.
So should i refer to kshapawi and do those necessary checks? I guess there is no harm doing checks. I'll get right to it tomorrow.
