Hi all,Firstly, thanks a lot for all the contributors to that forum. I've been reading and following since I owned my very first car - a BWM E36 318i Manual Yr 1994 - nearly two years ago.After doing some visual inspection on my bimmer this week end, I came across some fuel spills on my fuel sender unit (rear left side). I managed to clean all that mess. Every time I fill the tank up the maximum level (approx 62 litres), I can smell gas around the car, and this has been so since a year. Three months earlier I managed to 'smell' around and been able to locate the source : on the rear left wheel ! But never know where it comes exactly as the smell disappears after a week of running the car (12-15 litres consumed). As from here, the car will never smell gas anymore until the next fill up.From the picture, can anyone of you suggest what steps to be taken?1. Do you think I only need to check both clamps, as they look they have never been changed since factory. They are still the BMW type.2. I changed both clamps with new ones with screws ?3. Should the fuel hose be changed too, which looked as if they have been fitted since the car left the plant!I planned next morning to inspect more. Just in case there is a hairline crack on the plastic seal.. If so do you think this epoxy would be ok? Or it can damage the plastic cover ..?I would like to clean with carb cleaner.Scuff a bit with sand paperUse the epoxy. (how much should i wait until next drive. I feel i need to use the bus )Thanks a lot for your ideas. I swear I am afraid of driving this car
