Fan Clutch
Raymond@M-BeasT
sifu here...does anyone got the same problem like mine; :unsure: fan clutch on many times althought i didn't rev it really high or race????that sound is irritating me lots and made my car lose power everytime when the thingy on...it's choking... :angry: :angry: do u think if i change to a new fan clutch,it will be more smooth????? :blink:
If i'm not mistaken, the fan is triggered by temperature, not by load on engine.
Originally posted by Zoggee@May 4 2006, 01:28 AM
go to workshop and ask ur mechanic la.... why ask here. haha..
Ask mechanic if quotation too expensive & refuse to do will feel embarras ma...
E46 wor.. :blush:
Yes, the fan cut in at themperature, not the rev. Although when u rev. more heat is generated and therfore higher temperature.
One way to sove it, drive very very fast.......... :D
Sorry if i am mistaken but isn't the fan running at all times as long as the car is running? Thought the only fan that will go on/off is the aircon fan that depends alot on the thermostat. The main fan still runs as long as your car engine is on. Should the car starts to overheat even when the aircon's off, from my experience, it's actually time to change the fan cltch to keep it up to speed so the car doesn't overheat. Do share your opinions.
The clutch fan is engaged through fluid dynamics. The clutch fan contains a viscous liquid which, when hot, expands and pushes against the bi-metal bracket (the metal piece that is fitted at the centre of the fan clutch, thereby engaging the fan. As the engine cools, the fluid shrinks back and the clutch disengages.
I find that it works extremely well on my e21 and is fairly reliable, it will not die suddenly on you. Electric fans either work or don't work - can die on you without warning.
The aircondition fan does very little to keep the engine temperature down. Again, on my e21, my ac fan is getting weaker, not pushing enough air.... temperature goes pretty high with ac on when stuck in traffic. AC off - temperature is steady under the same conditions (only thing is, I end up drenched in sweat).
As with all mechanical items, there is a limit to how long it lasts. Better to change earlier, rather than later. Otherwise "penny wise, pound foolish" might apply.
Have it inspected by your regular mechanic and let him give you the proper advice.
From your avatar section, seems you are driving
Series: E46 99- 3 series
Model: 2001 313
ie. 1.3L engine? Wira ke?
underpowered ler...
Model: 2001 313
underpowered ler...
haha...cause i knew someone in the forum said his car is a 330 ci,so i purposely put mine as 313i..DUDE!!! :rofl:
