F10 Front Brake Replacement - BSRI Not Covered
e46er
Hi guys,
I'm due for a front brake pad replacement per the OBC. I've been confirmed by AB that the 5 years BSRI does not cover brake pad replacement. This is what was quoted by AB:
Front brake pads - RM 934.20
Sensors - RM 175.42
Include GST for both - RM 1109.60
Labour cost - TBConfirmed
Can you guys shed some light to me on what is the best option:
Is it worth doing it in AB or i can replace the brake pad at a specialist?
Would this void my BSRI?
Once the brake pads are changed, would it be able to be reset if i do i outside at a specialist?
Is it a must to change the sensor each time i replace the brake pads?
Help pls.....
Just replace outside bro. it'll b half the cost. but if u worry, AB is the way to go. BSRI im not sure. no perhaps?
Yes outside specialist are able to reset. even u can do it. its available on youtube on how to reset. its advisable to change sensors, less than rm100 anyway.
Bro Gendong,
Any place that you would recommend me to go outside? Appreciate of you can PM me.
